129 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> convert metric to standard
Tue, Jul 10, 2007 at 3:41:44 PM | convert metric to standard
ledge
Is there an easy or any way to convert a component/ family from metric dimensions to standard inch dimensions?
Tue, Jul 10, 2007 at 3:53:14 PM | convert metric to standard
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Settings-->Project Units
Revits dimensions are smart also.  In metric or imperial you can type dimensions in the opposite format and revit will do the conversion instantly.
HTH.
Regards,
Chris.
Tue, Jul 10, 2007 at 3:57:21 PM | convert metric to standard
ledge
also is there a way to get the dimensions within the component to switch from reading metric to inches?
Tue, Jul 10, 2007 at 6:14:29 PM | ledge
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting ledge from 2007-07-10 15:57:21
"also is there a way to get the dimensions within the component to switch from reading metric to inches?"
As I showed above...
GOTO Settings-->Project Units
Change your Length, Area & Volume units as required...  Doing this automatically updates the model.
Edited on: Tue, Jul 10, 2007 at 6:14:58 PM
Regards,
Chris.
Imperial to metric
Tue, Apr 27, 2010 at 10:53:09 PM
problems printing in metric
Wed, Aug 13, 2008 at 9:52:13 AM
my metric librarys gone?
Thu, Apr 17, 2008 at 12:35:27 AM
from inches to meter
Mon, Feb 9, 2004 at 6:36:53 AM
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Page generation time: 1.4729
