86 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> MEP work in Section view
Tue, Jul 10, 2007 at 12:37:31 PM | MEP work in Section view
jtoutant
When a section window is open, I'm unable to draw any ductwork or place any other mechanical equipment.  I could have sworn I did this in a tutorial.  Do I need to change the settings of my section?  How do I do mechanical work in section?
Wed, Jun 25, 2008 at 9:29:26 AM | MEP work in Section view
AVSteve
Revit 2008/2009 does not have the option to draw duct or pipe in section view.  I believe this will change in Revit 2010.
Wed, Jul 23, 2008 at 12:17:33 AM | MEP work in Section view
sitthugyiusa
Revit 2009 can draw duct in any section view.
No setting should be changed.
Wed, Jul 23, 2008 at 5:50:40 PM | MEP work in Section view
AVSteve
Guess I stand corrected.  Man we need to upgrade from 2008! Smile
MEP link to Architecture slow down
Fri, Dec 11, 2009 at 3:53:11 PM
Revit MEP
Wed, Oct 28, 2009 at 10:10:41 PM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:50 AM
Section or elevations not cutting imported dwg's
Fri, May 9, 2008 at 3:30:45 PM
rotating elements in section view
Thu, May 1, 2008 at 11:24:28 PM
Page generation time: 2.3440
