48 Users Online (47 Members):
Forums >> Community >> Newbies >> Is Revit able to do serious quantity surveying stuffs?
![ale02 Avatar](user_avatar/3109.jpg)
![3 Stars: 3 Votes](/images/stars_3.gif) |
Hi, everybody..
I got a few quick questions..
Just wondering is there anybody using revit's schedule for serious quantity surveying stuffs?
Any pitfalls?
No too sure about the accuracy of Revit's Quantity especially the pre-set areas and volume (e.g. for wall, floor & structures) and is there any way to counter-check or to know how Revit is programmed for those calculation?
Open for discussion!
----------------------------------- Life is never easy but nor it should be complex. Just stay simple ![Smile](/images/smiles/smile.gif) |
Its defintely feasible however i've never had the need myself so I haven't delved into investigating it. Remember early versions of revit did include quantity surveying software...
You are correct with the areas, i have found issues with incorrect (to a degree) reporting of areas...
But i know there are people out there using it for this very purpose...
Thanks for your reply, Mr. Spot.
Besides Area, I found that volume report sometime give some problems too. If you try to create a few simple structural family with extrusion (with solid and solid with void) and try the built-in volume report, it failed as it only recognized the full solid volumein both cases!?
Of course to some extents, we can use formulas to work out the actual volume extraction but this post question is how reliable the quantity reporting espcially those built-in pre-programmed one?!
Revit 2009 - Quantity Take offs |
Thu, Sep 9, 2010 at 4:41:22 PM
keynote text in schedule |
Tue, Nov 1, 2011 at 9:34:37 AM
quantity of balusters |
Tue, Nov 10, 2009 at 7:34:45 AM
rebar reinforcement quantity take off |
Mon, Apr 5, 2010 at 4:55:25 PM
quantity of colums |
Mon, Nov 23, 2009 at 2:36:32 AM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
