Forums >> Revit Systems >> Technical Support >> Leader-text gap
is there anyway to control the size of the gap between text and leader-i couldn't find any variable
I wish.....it's real annoying.....can someone at autodesk work on this.....
I really want this to work...some good things some bad |
46 Posts No Rating |
I will pile on, and "third" that comment. I hate that gap. It makes annontatons look amateurish!!
Make me the fourth! Get rid of the gap!! Its looks awful..or at least let us control the size of the gap..
Tim McDougald CHILDREY ROBINSON ASSOCIATES 1212 Kenilworth Avenue Charlotte, NC 28204 |
1 Posts No Rating |
Its FREEKIN' rediculous! Count in - Fifth!
iReplaced a PC! |
Can anyone tell me if this text-leader distance problem has been sorted out in the latest versions of Revit? And can the leader be positioned after the last line of text? I swear, I'd go through the expense of upgrading to 2010 just for the sake of having a professional-looking drawing for a change...
Sex, Drugs, and Revit... |
while you waiting for Autodesk to answer....here some music to put you in the mood, I think Kenny Nolan sums it up the best.... http://www.oldielyrics.com/lyrics/kenny_nolan/i_like_dreamin.html
Edited on: Wed, Jul 1, 2009 at 6:00:30 AM
The whole issue of the inadequacies of text in Revit just plain stumps me. How can a premiere program not do text better? I would never go back to ACAD but If I were able I'd steal some things such as a text editor and the adjustability we had with leaders and text. I have little hope for this anytime soon. I've come to the conclusion that the factory pretty much ignores the wish list and forums. If you look at the upcoming WU list, IMHO it looks like responses to support requests. They are taking care of basic issues and forcing the Ribbon into Revit.... Not so much in productivity or our wish list items. LOL, John
I have a blank symbol family and called it leader-so when I finish text instead of adding a leader from there I add the blank symbol and have a revit leader I can use-just remember to select at least 1 leader on the menu or you get nothing-just like a symbol you will have a revit leader with the option to add or remove leaders
3 Posts No Rating |
Add me in, such an amazing programme sort out the text! Its like trying to point without a finger
In case this helps here is my leader family (a blank symbol family). You can insert into project, then when you add symbol, select leader and make sure on the menu bar to the right you select at least 1 leader (it defaults to 0)-or it will be blank. It doesn't work like an autocad leader but it looks like one on construction docs-if thats where your conern is and it is a revit leader-just without the symbol-or text.
