54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Pilasters
56 Posts No Rating |
I need help with 2 questions. 1. I you have a wall with an EIFS finish, and you place a pilaster that has a brick finish, what is the best way to show this in plan view? If I join the pilaster to the wall, it takes on the EIFS finish. If I unjoin the pilaster, I just get an emply rectangle. Do I have to manually show the brick with detail lines? 2. What is the best way to place a pilaster on an outside corner where to exterior walls meet? The walls joins never seem to look right? Can you create in place? Or is there a better way? Using Revit 9.1 Thanks
Creating Wall Pilasters |
Sat, Jan 23, 2010 at 6:54:26 AM
Creating Wall Pilasters in revit |
Thu, Apr 17, 2014 at 11:26:21 AM
Pilasters and Brick Detailing |
Thu, Mar 20, 2008 at 2:43:34 PM
Isolated foundations attaching to columns |
Thu, Oct 16, 2008 at 5:15:41 PM
Column cleanup |
Thu, Mar 27, 2008 at 10:24:40 AM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
