77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> "inherit properties" when starting a wall
Tue, Jan 18, 2005 at 11:49:22 AM | "inherit properties" when starting a wall
nathanj
Is there a way to quickly set the wall type and properties to match a wall already existing prior to drawing it, or are you limited to drawing any old wall and then matching it, then editing its properties (ie base constraint, top offset, etc.)? Post edited on 2005-01-18 12:01:27 Post edited on 2005-01-18 12:02:40
Tue, Jan 18, 2005 at 2:35:00 PM | RE: "inherit properties" when starting a wall
mikefields27
In the upper left hand corner, there is a pull down menu which shows the default setting for whatever tool you are about to use. Once you pick the wall tool, use this pull down menu to select the type of wall you wish to draw. To the right of that, you may then select the hieght; more right is the location line; then the shape. You ca set all of these to get the wall right, the first time you draw it.
Tue, Jan 18, 2005 at 3:25:49 PM | RE: "inherit properties" when starting a wall
nathanj
Im familiar w/ all that.....What im looking for is a quick select/inherit properties function...similar to the eyedropper tool, that will set the properties of an object based on an in-place object.
Wed, Jan 19, 2005 at 4:36:37 AM | RE: "inherit properties" when starting a wall
Steve_Stafford
5 Stars: 2 Votes
In 7.0 the match properties command will now also carry instance parameter changes to a wall from the source. The create similar command will allow you to place a wall based on the wall you pick prior to starting the command. Check out the What's new in this Release part of the help files.
Loading Curtain Wall Door Types
Fri, May 8, 2009 at 3:20:53 AM
Missing Element Properties Ribbon
Fri, Aug 20, 2010 at 2:43:21 PM
System Wall Properties
Wed, Mar 18, 2009 at 12:55:05 AM
Is it possible for Students using a Student copy of Revit to work on a project?
Fri, Mar 13, 2020 at 10:20:14 AM
rfa uzantılı dosya indirimi
Fri, Dec 27, 2019 at 4:09:22 AM
Page generation time: 4.7352
