101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> DWF File Size
Mon, Jul 2, 2007 at 8:48:55 AM | DWF File Size
jterrell
3 Stars: 5 Votes
When exporting a 2d dwf, the file size is huge! For example, I exportes some sheets from revit and the dwf size was nearly 3200kb, I then opened the sheets in Design Review, and re-saved, not the dwf file size is ~800kb, which is more suitable for email. Don't know if this is a bug, but it would be nice to have revit save smaller dwf files.
Mon, Jul 2, 2007 at 10:48:15 AM | DWF File Size
sdbrown
5 Stars: 3 Votes
If the view has raster images it will be a large file. Also there is an option when publishing to dwf to inclued model objects and room area. If you don't need to list the objects in the dwf uncheck these and it will be smaller also.
Fri, Oct 26, 2007 at 9:52:19 AM | DWF File Size
GroovinYEM
Has anyone figured this out?  My file size with the 2008 "Publish DWF > 2D" averages 3mb per drawings and with the old DWF writer they averaged less than 500kb.  Is there a fix?  None of the drawings have raster images.  I've tried with "Model Elements" on and off, same results.  Please help!  I have to DWF a set of about 50 drawings and the file size is almost as large as the .RVT file size.
help! dwf for 2d plans
Sun, Feb 26, 2006 at 8:15:58 PM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:12 AM
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:42 PM
DWF Linking
Thu, Aug 23, 2007 at 12:55:33 PM
dwf file (light source)
Mon, Feb 2, 2009 at 11:28:10 AM
Page generation time: 1.5101
