Forums >> Revit Building >> Technical Support >> IFC file import
10 Posts No Rating |
I have tried importing IFC file by File>Import/Link>IFC in Revit 2008. I am not sure what’s wrong but the file does not import in to project. Please share your thoughts. Thanks
Never mind. I have tried ifc 2x model and that worked like charm. Thanks,
2 Posts No Rating |
I have tried both ifc 2x and ifc2x3, but failed to import any file. Got an error message for both the format: "The following problems were encountered in the IFC file: Error 20056: Error opening the temporary swapfile!" can anyone please help me to get out of this.
1 Posts No Rating |
Hello saif33943, I got the same message when importing IFC files: "The following problems were encountered in the IFC file: Error 20056: Error opening the temporary swapfile!"
Did you resolve this issue? If so, please provide some advice. Thanks.
1 Posts No Rating |
I had the same error 20056, aperrantly it meens that your swapFile is not big enough. I fallowed instructions on this link and increased size of a swapFile to recomended, after thet had no error message again, and no problems with importing IFC .
No Import - Maximum size of IFC imports? |
Sun, Jul 10, 2016 at 6:56:31 AM
IFC import intoRST2010?.. |
Fri, Mar 26, 2010 at 2:07:18 PM
Revit export/import to IFC - ceilings and floors (ifccovering) |
Mon, Jul 28, 2014 at 3:22:59 PM
IFC detail drawing into Revit |
Mon, Nov 25, 2013 at 2:31:32 AM
Revit to Ifc to Third Party BIM Viewer |
Tue, Dec 11, 2018 at 12:36:04 PM
Members: | 2098988 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
