104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Room tags in callout views.
Thu, Jun 28, 2007 at 4:30:53 PM | Room tags in callout views.
OPIE
using revit 2008
I solved the callout issue. downloaded the newest version of revit. Now when i create a callout on a floorplan, and then go to that newly created view. all the dimensions and the room tags detail lines disappear. i can CC the detail lines, that was easy. the dimensions i can put back in. Room Tags i try to place new ones it seems to place them but i get the same visibility warning msg that i was getting when the callouts where not working.
 I checked the visibility and rooms are on. as well as the dims. toogling the crop region on/off doesn't effect weather or not they show.
i tried to make both floorplan view and a detail view.  both have the same problem
room tags in sheet view
Thu, Jun 8, 2006 at 9:35:24 AM
Door/Room Tags in Callout Detail
Thu, May 17, 2007 at 3:18:42 PM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Room tags in section views
Tue, Sep 27, 2005 at 4:39:14 PM
How to make one callout tag with multiple views referenced
Thu, Aug 22, 2013 at 9:04:24 AM
Page generation time: 0.7029
