50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> axons
Thu, Jun 28, 2007 at 11:26:10 AM | axons
jrosenwald
what is the best way to do axons in revit 9.1?
Thu, Jun 28, 2007 at 11:57:45 AM | axons
NightRyder
what kind of axons are you trying to do? you can simply rotate the model in 3d or you can use a camera to specify a specific viewpoint placement/elevation and target elevation to get more accurate (this will result in a perspective view)...just depends on what you want your final output to be.
setting numerical angle for axonometric?
Fri, Jun 6, 2008 at 12:40:52 PM
Camera views export blank images
Mon, Dec 9, 2013 at 1:40:17 PM
Curtain Panel Surface Pattern not showing in 3D View when set to Hidden Line
Fri, Jun 17, 2011 at 2:00:20 PM
Page generation time: 0.2747
