69 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Floor plans to Structural plans
Wed, Jun 27, 2007 at 8:28:15 PM | Floor plans to Structural plans
DaveF
Hi
I'm using RS4.
I started a model, passed to our architect & he returned it with an extra level which is defined under Floor plans.
Is there a way to move it in the project browser to list under Structural plan? I've tried changing the Discipline to Structural & Drag 'n' Dropping, but with no luck.
Any ideas would be gratefully received.
Cheers
Dave F.
Thu, Jun 28, 2007 at 6:15:56 AM | Floor plans to Structural plans
framerman
4 Stars: 13 Votes
Dave,
My first thougt would be changing the discipline like you said. Did he happen to change the browser organization, like maybe the order?
If you have separate "architectural" and "structural" in your browser, it should change under discipline
Thu, Jun 28, 2007 at 6:17:23 AM | Floor plans to Structural plans
framerman
4 Stars: 13 Votes
Maybe also post a picture of your browser with sub trees opened.
Sun, Sep 25, 2011 at 3:36:56 AM | Floor plans to Structural plans
morgan68
framerman
hi
if you change Discipline it will just change the family of the plans, i tried to change the type of plans but they do not change.
I realized if we create a plan in revit architectural it will be floor plan and in revit structural it will be structure plan. but must have a
way to change them!
Fri, May 4, 2012 at 11:13:29 PM | Floor plans to Structural plans
npage
On the view tab, sleect plan views then floor plans. Then at the top of the dialogue box select structural and select the floor plans that you want to be structural. this will create a new plan in the correct category as well as leave the original floor plan. if you don't want a floor plan and structural plan you can delete the floor plan once the structural plan is created. This process works to change floor plans to structural plans as well.
Views: Structural Plans vs Floor Plans
Fri, Jul 7, 2006 at 4:59:19 PM
Structural Plans vs Floor plans
Mon, Jan 30, 2017 at 11:49:21 PM
VERY INTERESTING QUESTION
Thu, Sep 11, 2014 at 7:11:23 PM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:34 PM
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:22 PM
12
Page generation time: 2.6234
