47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Dimension Text Overide
Wed, Jun 27, 2007 at 6:35:10 PM | Dimension Text Overide
hkleoiki
Does any one know how to change the dimension text? With autocad based programs you culd change it through the properties manager and input any string of text that you wanted. in revit i changed the dim to opaque and wrote over it but it looks a little funky.
Wed, Jun 27, 2007 at 7:10:25 PM | Dimension Text Overide
framerman
4 Stars: 13 Votes
Revit theoretically won't let you do this.
However, there are a few workarounds. One is to create a new dimension style with your text as small as you can get it (1/32" rings a bell for me) then simply place text over it with the opaque option selected. This will hide the dimension.
Another is using an invisible font.
Wed, Jun 27, 2007 at 7:13:42 PM | Dimension Text Overide
framerman
4 Stars: 13 Votes
And I can't edit what I said because I saw what you said and needed to edit my answer so I didn't look so obviously dumb because I didn't really read your entire thread Smile
Now that I did, I would just make your dimension style text smaller and cover it.
editing dimension text
Wed, Jun 7, 2006 at 9:33:16 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Page generation time: 0.4541
