77 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Can't load annotations
1 Posts No Rating |
Hi AllI am currently using Revit Architecture 2008 and am unable to load Annotations into my projects. When clicking on Symbols in the design bar, this prompt appears. "No generic annotations family is loaded in the project. Would you like to load one now?" Then I click "yes", open the Annotations folder, select a symbol, then the following pops up:"The family is not of the correct category".Am I doing something wrong? Thanks
![4 Stars: 10 Votes](/images/stars_4.gif) |
Try finding the annotation that you load under the project browers and click and drag it into place on your plan. After that, you should definatly see it either under Symbols. If that doesn't still, I dont think it is loading as a Symbol, you might check other categoires i.e. Detail Componants HTH
cannot load families into my project |
Tue, Aug 15, 2006 at 2:20:21 PM
Annotations Gray'd out? |
Thu, Sep 20, 2018 at 12:53:00 PM
I can't load anything from my library. |
Thu, Jul 25, 2013 at 10:16:10 AM
Families won't load? |
Tue, Sep 2, 2008 at 1:17:06 PM
sections - level annotations |
Mon, Sep 5, 2005 at 7:33:03 PM
Members: | 2022294 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
