41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Anyway to attach wall bases to toposurface??
Sun, Jan 16, 2005 at 8:50:00 PM | Anyway to attach wall bases to toposurface??
riksta
Wall bases & tops seem to only attach to roofs, floors & reference planes etc. Can they be attached to toposurface?? I know the wall bases can be dragged below the toposuface, but I don't want the walls protruding below to be visible in elevations. The lowest part of the elevations should be the toposurface which is obviously the ground line. Any Suggestions??
Sun, Jan 16, 2005 at 10:43:59 PM | RE: Anyway to attach wall bases to toposurface??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There is no way to attach walls to a toposurface. The methods to achieve what you want include: In-place family void that cuts the bottom of the wall at the toposurface level. My preference, just put filled regions for the site in elevation. I've used this method in most instances.
Mon, Jan 17, 2005 at 12:08:15 AM | RE: Anyway to attach wall bases to toposurface??
riksta
Thanks spotty I'll give it go!
Sat, Dec 30, 2006 at 5:32:26 PM | Anyway to attach wall bases to toposurface??
diceman93
could you clarify how to create a void from the toposurface.  I don't understand how to cut the bottom of the wall.  Thanks, Noah
Sun, Dec 31, 2006 at 9:23:21 AM | Anyway to attach wall bases to toposurface??
robinballew
robinballew Avatar
3 Stars: 4 Votes
It sounds like you need to adjust your elevation cut line. Your Topo will should have a thickness deeper than your foundation wall. At that point your elevation marker or at least your cut plane should cut the topo. If you do this you will not be able to see the foundaiton.
BallewDesigns.com
Attach Wall up to Roof
Tue, Oct 2, 2007 at 3:57:57 AM
Shop Drawing requests for CAD bases
Fri, Aug 6, 2010 at 5:03:01 PM
Attach curved curtain wall to sloped roof RAC 2008
Tue, Apr 21, 2009 at 1:08:09 PM
Continuous footings for the Piers
Mon, Sep 30, 2013 at 12:23:16 PM
Toposurface glitch?
Thu, Jul 18, 2013 at 9:34:40 AM
Page generation time: 0.8260
