147 Users Online (146 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> walls
Sat, Jan 15, 2005 at 8:54:40 AM | walls
bambafix
5 Stars: 4 Votes
hi i'm italian and i can speak english very well . iwant to ask if in revit i can draw a sloping walls example a walls at star is at 0 height and the finish is at 6 metres height
Sun, Jan 16, 2005 at 5:52:41 PM | RE: walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes you can. View the wall in elevation. Select the wall and choose "edit elevational profile" then simply change the shape of the wall to what you need.
Mon, Jan 17, 2005 at 2:38:04 PM | RE: walls
bambafix
5 Stars: 4 Votes
thank you!!!!
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:43 PM
Walls
Thu, Dec 16, 2004 at 4:56:58 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:27 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:19 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:36 PM
Page generation time: 0.8338
