Forums >> General Discussion >> Revit Project Management >> ELEVATION TAGS
13 Posts No Rating |
HOW CAN I CHANGE THE ELEVATION TAG WITH A FAMILY THAT I CREATED? I HAVE TRIED TO DO IT BUT I CAN´T CHANGE IT IN THE PROPERTIES WINDOW.
There are a ton of things that you could have done wrong. The easiest thing I can think of is to just go modify the elevation annotation that you are wanting to change. Then save it as a different name, and load it into your project. You should then be able to select it from the drop down to choose the new type. Other than that I cant really say why you dont see, just many different things that could be the culrprit. HTH
Select an existing level, go to its properties-->edit it and then choose your symbol from the drop down menu for symbol...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
THANKS FOR ALL THE INDICATIONS BUT I ALREADY DONE WHAT YOU SAID. THE THING IS THAT WHEN I OPEN THE DROP DOWN IT ONLY SHOWS ME TWO OPTIONS FOR THE ELEV TAG THAT COME IN THE PROGRAM AS DEFAULT AND IT DOESN´T SHOW ME THE ONE THAT I CREATE AS A FAMILY AND LOADED INTO THE PROJECT. THERE MUST BE SOMETHING ELSE THAT I HAVE TO DO PREVIOSLY.
Do you mean Level Heads or Elevation Markers? Level Heads are a family and are just loaded in. Elevation markers are a system family and exist only in the project. To change these go to Setting-->View Tags-->Elevations...
Regards,
Chris.
3 Posts No Rating |
Great! Solved my problem instantly! I guess the solution on your website, Chris, is only needed if you really want to customize de look of the tag?
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:40 PM
Elevation Tags |
Tue, Oct 23, 2007 at 4:30:07 PM
Custom Elevation Tags |
Thu, Mar 17, 2011 at 5:09:03 AM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:58 AM
Multiple Elevation Tags |
Mon, May 24, 2010 at 3:20:17 PM
Members: | 2105945 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
