83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> couter top for a curved wall
Mon, Jun 25, 2007 at 6:12:09 PM | couter top for a curved wall
ledge
How can I get a counter top to attach to a curved wall and carry the same radius as the curved wall?
Mon, Jun 25, 2007 at 11:06:39 PM | couter top for a curved wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use pick walls to draw your sketch or pick lines or just draw your sketch to the same radius?  Maybe i'm misunderstanding what your asking...
Regards,
Chris.
Tue, Jun 26, 2007 at 7:17:37 AM | couter top for a curved wall
hammer87
hammer87 Avatar
3 Stars: 4 Votes
what i would do is create a new floor make it the countertop thickness, i usally make mine about 2", then just use floor tool and pick the walls and elevate it like 3ft.
My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087
Tue, Jun 26, 2007 at 8:28:55 AM | couter top for a curved wall
latemore
latemore Avatar
3 Stars: 2 Votes
i might suggest a subtlety here - if doing 'casework' in revit, sometimes best to do it as that category, so revit's visibility abilities can be used well.  not as a floor maybe.  we tend to do kitchen cabinetry for instance as in place families, under the casework category.  that way it is easy to tick on or off in any view.  we also find in place families have a lot of power when doing cabinetry, as you end up with one item in the model.
Tue, Jun 26, 2007 at 10:13:34 AM | couter top for a curved wall
ledge
when you say do it in the casework catagory, what exactly am I doing in the casework catagory? are there no  predefined counter tops that have curved edges that you can adjust or not ones that are fixed? If you suggesting that I create my own countertop which is the best way to go about doing so.
Tue, Jun 26, 2007 at 10:26:02 AM | couter top for a curved wall
MrBob
3 Stars: 2 Votes
  1. From the Modelling menu, choose Create or click Create from the Modelling tab of the Design Bar.
    The Family Category dialog box appears.
  2. Select the appropriate family category. In this case choose "casework"
  3. Choose the family category and click Proceed.
  4. In the Family Name box, type in a family name and click OK. "curved countertop"
  5. When you finish creating the in-place family, click Finish Family to end creation of the new in-place family.
Mon, Jul 2, 2007 at 1:29:57 PM | couter top for a curved wall
ledge
thank you that was very helpful. I have another question. One of the custom counter tops that I created I am able to adjust the edges to make longer or wider, one other that I created I cannot adjust? Is there a setting that I missed?
Mon, Nov 22, 2010 at 12:45:45 PM | couter top for a curved wall
imsok3wl
i am trying to add in a curved counter. i am using revit architecture 2011. i don't have a modeling tab--i have model text, model line and model group. if i click model group i don't get a drop down menu as descirbed below. is there a different way to do counters now?
Mon, Nov 22, 2010 at 1:03:00 PM | couter top for a curved wall
home tab - component - model in place.
Mon, Nov 22, 2010 at 5:02:47 PM | couter top for a curved wall
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
There was a total redesign of revit's UI in version 2010, so old threads like this cannot be taken literally.
HELP! Curved Sloped wall with slanted top
Sat, Jul 26, 2008 at 9:16:29 PM
12
CURVED WALL WITH TAPERED TOP
Mon, Oct 29, 2007 at 4:52:13 PM
Complex Curved Walls - please help
Wed, Mar 25, 2009 at 5:26:10 PM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Curved wall editting
Thu, Apr 6, 2006 at 2:41:09 PM
Page generation time: 0.9640
