73 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> RENDERING-region raytrace
Fri, Jan 14, 2005 at 3:38:24 PM | RENDERING-region raytrace
mchiche4
When I do a region raytrace, the resulting rendering is clipped and left blank below the 0'-0" elevation of my model. Is there a setting that i'm missing which is not allowing the full render to happen.
Sun, Jan 16, 2005 at 5:49:29 PM | RE: RENDERING-region raytrace
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Region raytrace is done so be select this option then drawing a window around the selection you wish to render. If you wish to render the whole view within the crop region simply use the raytrace option. HTH.
Raytrace and region raytrace not working!!?!
Sat, Oct 11, 2008 at 9:19:03 AM
Raytrace region
Wed, Aug 9, 2006 at 5:23:23 PM
Radiosity and Raytrace Rendering
Mon, Jun 21, 2004 at 11:50:06 AM
Revit 2013 Raytrace
Fri, Jan 25, 2013 at 12:01:05 PM
Rendering Tree/Shrubs
Thu, Oct 5, 2006 at 11:22:39 AM
Page generation time: 0.5297
