69 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Multi-building Schedule
Mon, Jun 25, 2007 at 3:57:56 PM | Multi-building Schedule
chilenito
Hi,
Is it possible (and how to) to create a multi-building schedule? We are working on a project that relates 5 buildings, each one of them has its own schedule, but we wouyld like to have them in one sheet. how do I do that?
Do I have to insert those 5 buildings in the master plan and then try to get the schedule of all the buildings? or should I export each schedule in to autocad and that xref them to a file with the titleblock included?
Any ideas?
Matias Santini
Mon, Jun 25, 2007 at 5:46:18 PM | Multi-building Schedule
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You should have a master site file that has the other buildings linked into it.
Then create your schedule in the master file with the "include links" option turned on.  You can also group and sort by what building the schedule refers to.
HTH.
Regards,
Chris.
Thu, Jun 5, 2008 at 12:02:25 PM | Multi-building Schedule
NKramer
4 Stars: 9 Votes
I know this thread is a bit old, but I cant seem to find what I am looking for.
I have door and finih schedules that need to include elements from linked files. So I turned on the include linked elements and now they will no longer allow me to filetr by level. The level show up correctly and as a field in the schedule, but it is no longer on the list for filtering.
I tried copy/ monitoring the levels in and still no luck. Am I missing something? or is this a bug/ not possible?
thanks,
Nick
Mon, Jun 9, 2008 at 3:43:31 PM | Multi-building Schedule
NKramer
4 Stars: 9 Votes
Is this just not possible or have others not run into the same issues?
thanks,
Nick
Edited on: Mon, Jun 9, 2008 at 4:05:37 PM
Multi-Category Schedule with Links
Wed, Aug 10, 2016 at 6:23:56 PM
Multi category schedule with volumes and areas!
Thu, Apr 28, 2011 at 1:21:54 AM
Element Keynotes on Multi-Cat Schedules
Thu, Dec 28, 2023 at 10:07:15 AM
Thu, Jul 26, 2007 at 4:06:09 PM
MULTI-CATEGORY SCHEDULE
Wed, Dec 29, 2010 at 4:45:25 AM
Page generation time: 1.2202
