53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Door in brick wall
56 Posts No Rating |
Does anyone have a door type that will cut into a metal frame wall with brick? I am working in 9.1. The wall I have to place the door in is brick all around the door. I would like to be able to show the brick stopping at the frame in both plan view and elevation view. Any help would be appreciated. Thanks
![5 Stars: 3 Votes](/images/stars_5.gif) |
You need to create ref. planes in the family that you define as the wall closure. then in you brick wall type make sure you set the wall to wrap at exterior, interior or both.
Thanks,
I did that, but now I don't see my door frame in the plan view. The opening is right, but no frames. I am sure it is related to the door family. Any ideas?
see through door opening to door beyond |
Mon, Nov 2, 2009 at 1:46:12 PM
Wall Wrapping |
Tue, Nov 15, 2005 at 6:05:05 PM
Wall Parts - Brick below door sill |
Wed, Dec 31, 2014 at 2:55:43 PM
New Wall with Brick |
Tue, May 26, 2009 at 9:36:24 AM
Brick arch around elliptical head on door. |
Fri, Oct 19, 2018 at 10:54:46 AM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
