45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> walls wont hatch in plan...?
Mon, Jun 25, 2007 at 10:16:57 AM | walls wont hatch in plan...?
LUCAS1979
1 Stars: 1 Votes
I got an issue with my walls... my second floor is located in the attic and therefore most of the walls are various height. to make my life eisier I set up all of the walls to 4' and my cut plane to 3' so the view still cuts them... the thing is that unless the wall is above 6' tall the view wont show individual componenet & hatch the inner core (instead it looks like in course view: outline and blank inside) i was thinking it might be view rande issue but i played w/ it left and right and nothing? is it the wall itself? it works fine on the first floor but there it goes all the way up to the ceiling 8'...
Tue, Jun 26, 2007 at 1:37:36 AM | walls wont hatch in plan...?
Safety
1 Stars: 1 Votes
Check the following:
  • scale of the drawing influances cut pattrens they do not show if the scale is 2 small
  • visibility settings
  • material settings
  • cut patterns setting
  • it could also be affected by imports if you have any
  • check your view range again, its easy to have it set up wrong
You will have to play around to get the pattern to show!
Tue, Jun 26, 2007 at 11:51:24 PM | walls wont hatch in plan...?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Walls with an unconnected height unless than approximately 1800mm (would have to check the number) high will not show cut even if they are being cut by the cut plane.
 The solution being to make them reference a level with an offset, even if its the same as the base level..
IE:
Start = Level 1 Offset 0
End = Level 1 Offset 1500
This would correctly show cut.
HTH.
Regards,
Chris.
Wed, Jun 27, 2007 at 1:54:22 AM | walls wont hatch in plan...?
Safety
1 Stars: 1 Votes
why would that be Mr. Spot ?
It doesnt make sense to me that it would not cut the wall?
Which Revit version are you using LUCAS1979??
Wed, Jun 27, 2007 at 8:19:05 AM | walls wont hatch in plan...?
LUCAS1979
1 Stars: 1 Votes
I think Chris is onto something 'cause i was lowering wall [just to see whats up] from 8' to 4' every 6" and it stopped hatching below 6'... it sucks if thats the case, [you would think that as long as the cut-plane is cutting object it would show hatch...?] I'll play w/ offsets... if it wont work ...I'll B BAAK...      ps. I'm on 9.1...
Wed, Jun 27, 2007 at 9:51:45 AM | walls wont hatch in plan...?
Safety
1 Stars: 1 Votes
Hi LUCAS1979
You can use plan region to set the cut plane at different areas on plan, it should also work for your walls!
I have used it and it works great!
I have applied your wall settings and changed my view range and it seems to work fine in my project? Maybe i'am just doing it right?
Wed, Jun 27, 2007 at 5:40:09 PM | Safety
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting Safety from 2007-06-27 01:54:22
I assume so in plan its easily evident that these walls are not full height...  Personally I don't see what the big deal is.  Its no harder to use a level offset instead of an unconnected height?
I didn't design the product I just use it.  I agree if its cut by the cut plane it should show cut, i think everything should have a realistic cut (like windows and doors) but unfortunately they don't unless the element is a generic model.  There was probably some reason for doing it.
Regards,
Chris.
Thu, Jun 28, 2007 at 3:34:55 AM | walls wont hatch in plan...?
Safety
1 Stars: 1 Votes
"I didn't design the product I just use it ". Quoting Mr. Spot
Same here! Just thought you might know!
I agree it's not a big deal! We have to ask why they developed the product in such a manner in order to correct these little mistakes for the future. Maybe then we will have a finely tuned program!
Thanks for replyinng Mr. Spot!
Wed, Mar 18, 2009 at 2:48:47 PM | walls wont hatch in plan...?
quinn
Safety can you show us a sample of a wall 5' high with the normal view range at 6' and a plan region that will show a poriton of a wall with the hatch within?
I have tried this and do not see the plan region showing any hatches below 6'.
Wed, Mar 27, 2013 at 12:13:01 PM | walls wont hatch in plan...?
mike102
3 Stars: 2 Votes
I just had this same problem it was in revit 2013. If you go under Visibility and Setting, then go to walls, then go to pattern overide under the cuts column and change it to clear all overides. It will show your cut pattern in plan. Hope this helps its actually a relatively easy solution. In revit your plan is automatically defaulted to show cut patterns as white you just have to change it.
-mike
Wed, Mar 27, 2013 at 3:22:00 PM | walls wont hatch in plan...?
Mr Spot's answer is better than having to do an over-ride.
HATCH IN FILLED REGION WONT SHOW
Wed, Oct 1, 2008 at 8:59:51 PM
Plan Region not shwoing wall hatch??
Mon, Jan 14, 2008 at 12:03:29 PM
Revit Area Plan - Furniture & walls are showing area hatch
Fri, Mar 20, 2015 at 12:21:21 AM
Number hatch for ceiling plan
Mon, Dec 17, 2007 at 12:48:09 PM
Walls not showing in plan region
Mon, Feb 18, 2008 at 1:59:12 PM
14
Page generation time: 2.1939
