48 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Coarse section view
12 Posts No Rating |
How do you change the default solid blue hatch in the section view? I've looked everywhere and can't find it. Thanks Rosario
![4 Stars: 10 Votes](/images/stars_4.gif) |
Default solid blue hatch for what? Wall, ceiling, roof, detail componant, filled region...?
Everything. Draw a quick house and make a section. Than click on coarse detail. Everything being cut turns to solid blue. I'm guessing its a default for a course section.
![Aguel Avatar](user_avatar/31.jpg)
![4 Stars: 8 Votes](/images/stars_4.gif) |
It's the default poche material color blue change it to anything you like and you are done. HTH
I know its the default. Where is the option to change it? Thanks
Go to settings and in the drop down menu click material look for poche material then change its color to anything you like.
I'm sorry. I forgot to state that I am refering to the 3d section box. Not a section. I don't see anything about a default section pattern under settings - materials. Wouldn't it be in a more general option dialog? If I have a detailed building it doesn't make sense for me to go into each material and change its coarse scale section pattern.
![5 Stars: 3 Votes](/images/stars_5.gif) |
Click Settings, Material, scroll down to poche, modify the cut pattern color as you like. This is a global setting, not by each assembly type. The section box defaults to this poche material for course scale.
oh ok I gotta got it now. Thanks alot guys
transparent object in coarse view |
Mon, Nov 8, 2010 at 12:00:41 PM
Lineweight of steel column in coarse view |
Fri, Jan 7, 2011 at 6:25:48 PM
Show brick veneer in coarse view |
Fri, Aug 1, 2008 at 11:38:05 AM
Coarse view not displaying for face based models |
Mon, Nov 14, 2016 at 8:57:17 AM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols |
Mon, Jul 30, 2012 at 7:12:54 AM
Members: | 2022368 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
