144 Users Online (143 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Barrel vault dormer opening
Thu, Jun 21, 2007 at 11:38:38 AM | Barrel vault dormer opening
tebeane
I have a barrel vault with a barrel vault dormer. I am trying to cut the opening in the main vault for the dormer but with no luck. The two arches intersecting are a problem??? Any suggestions?????
teb
Thu, Jun 21, 2007 at 12:01:47 PM | Barrel vault dormer opening
broncos4life
3.5 Stars: 11 Votes
How are you trying to make each vault? Are they cut walls, arched ceilings, or what?
Thu, Jun 21, 2007 at 12:13:39 PM | Barrel vault dormer opening
tebeane
I am creating the dormer barrel vault roof with the roof extrusion tool. I created the main barrel vault the same way. Does this help?
Thu, Jun 21, 2007 at 12:18:50 PM | Barrel vault dormer opening
broncos4life
3.5 Stars: 11 Votes
Did you try the "Join Geometry" comand, or the "Join/Unjoin Roofs" comand?  If you have and it still hasnt worked. You might try massing and then do Roof by Face.
Thu, Jun 21, 2007 at 12:58:57 PM | Barrel vault dormer opening
tebeane
I have tried the join roofs and join geometry. The roofs do join but it does not cut the opening in the main barrel vault at the dormer. I have tried the dormer opening command but with no success. I guess due to the curvred edges where the barrels intersect??? Why are the openings not automatically created when you add the dormers?
I am not familiar with your other suggestion of massing and roof by face?
Thanks for your input
Thu, Jun 21, 2007 at 1:19:56 PM | Barrel vault dormer opening
broncos4life
3.5 Stars: 11 Votes
Revit 9.1 or 2008?
Thu, Jun 21, 2007 at 1:22:28 PM | Barrel vault dormer opening
tebeane
Revit 2008. I have worked on Revit 9.1 for about 4 months (still learning!) but recently loaded 2008 which is what i am working in now.
Thu, Jun 21, 2007 at 1:36:55 PM | Barrel vault dormer opening
broncos4life
3.5 Stars: 11 Votes
Is that what you are looking for?  Let me know, and I will explain how I did it.
Thu, Jun 21, 2007 at 1:44:07 PM | Barrel vault dormer opening
tebeane
Yes. I have two barrel vaults (in a "T" shape) intersecting as your drawing shows. I am also trying to add a barrel vault dormer as discussed and would be the same proceedure I assume. I will look for your explanation.
Thu, Jun 21, 2007 at 2:14:48 PM | Barrel vault dormer opening
broncos4life
3.5 Stars: 11 Votes
Ok, I will explain it really simplisticly first if you still have troubles let me know.  I couldnt find a way to do this with roofs, what I ended up doing was creating an implace family that was a roof family.  This way you can draw the extrusions that you want and then void out the parts that you dont want.  Doing this all as one family.  So just use the Solid and Void forms of an implace family to draw what you want it to look like.
Thu, Jun 21, 2007 at 2:22:50 PM | Barrel vault dormer opening
tebeane
Thanks, i will try this. Have a good afternoon!
How do I create a Barrel Vault Ceiling
Fri, Apr 26, 2013 at 4:09:24 PM
Standing Seam on a barrel vault roof
Tue, Jul 23, 2013 at 9:06:23 AM
Tue, Oct 21, 2008 at 10:12:05 AM
Trouble with creating a Ribbed Groin Vault
Sun, Nov 25, 2012 at 12:04:45 PM
Barrel Vault Roof
Thu, Sep 2, 2004 at 8:50:50 PM
Page generation time: 0.2941
