114 Users Online (113 Members):
Forums >> Revit Building >> Technical Support >> Hide Element and Printing
11 Posts No Rating |
Hi, If I use the "sunglasses" and hide an element, when I print, the hidden element prints. Is there a way to have the hidden element not print? -Joe
Depends. If you have 2 couches and you want 1 couch two show and the other not, you need to set up a filter. If you have 2 couches and you dont want any of them to show along with any furniture you can shut off furniture in Visibility Graphics. Note: This is only true for Revit 9.1, please post what Revit you are using when you post as well.
2008
Ah, that makes it much easier for you. Click on the element, right click, and go to "Hide In View" and then go to "Element." That will make it so that it does not print.
1 Posts No Rating |
I have the same problem, i wana hide some objects (not categoris) and print without them, but my revit is 9.0 and I don't fine the "hide in view". What should I do? Heeelp meeee
12 Posts No Rating |
It may be possible to use Design Options to hide these things. Create an empty design option as the primary, and put the elements you don't want to see in the alternate design option. Also, you may be able to put those elements on another workset and then use selective workset loading. Worst case scenario, use a white filled region with invisible lines to hide them, or use the linework tool. Those be my thoughts.
One last thought - you could create a view filter that operated on the family:type name of those components, and rename or duplicate/rename those components as necessary to make the filter work.
Hide element in all views |
Fri, Apr 20, 2012 at 7:07:04 AM
Hide Labels In Border When Printing |
Tue, Jan 20, 2009 at 1:38:50 PM
Hide 'Contour' Lines in Modified Sub Element |
Tue, Dec 3, 2013 at 9:21:03 AM
NON-PRINTING LAYERS?? |
Thu, Jan 17, 2008 at 4:58:33 PM
Creating an element that only appears in one view |
Fri, Feb 7, 2014 at 8:31:38 AM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
