45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Split walls
56 Posts No Rating |
When you split a wall, is there a way to not see the split line in an elevation view? I would like the wall to look like one wall not 2. Thanks
![4 Stars: 10 Votes](/images/stars_4.gif) |
If the wall types on either side of the split are not the same type try to "Join Geometry", if they are the same wall type what is the reason for the split (if you dont mind my asking)...but if they are the same type, you can use linework in elevation and make them "<Invisible Lines>" and then they shouldnt show. The linework tool is 2 to the right of the tape measure tool.
using split face tool on curved walls |
Sat, Oct 12, 2019 at 8:21:20 AM
Can't split certain faces |
Thu, Dec 6, 2012 at 6:59:31 AM
Split face aournd a corner... |
Tue, Aug 25, 2009 at 2:14:22 PM
split face not remembering material - RAC 2008 |
Thu, Nov 20, 2008 at 3:13:31 PM
Using Split Face |
Fri, Jul 12, 2013 at 11:00:40 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
