111 Users Online (109 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit 2008 to Max 9.0 with VRay
4 Posts No Rating |
I am having issues with importing between revit and max. Eporting to 3D DWG and then linking the DWG in max works fine, but as soon as I try to render the render window gives a 'transforming vertices' message that runs for an inordinately long time. This process with a revit generated file takes about 10 times longer than with a native Autocad file. Any ideas on how to speed up this process? We have tried to 'clean' the file in autocad (purge & audit, and even pasting it into a clean drawing) but to no avail.
18 Posts No Rating |
I experienced the same problem when importing revit model into max (using link manager to link dwg) and render in Vray.
4 Posts No Rating |
We have been through this a couple of times now, and find to date that using max 8 with an older vray works. As soon as chaos group finally gets the dongle for the new vray here we are hoping that this latest release vray will fix this (at least that is what the guys at chaosgroup tells us).
really good to know! "using max 8 with an older vray works", which version works?
4 Posts No Rating |
Max 8 & vray RC2 works for us.
Thanks for the information, can you please give me the exact version number of Vray which works for you? Currently we are using V-Ray Adv 1.5 RC3 in max8.
4 Posts No Rating |
We are using 1.5 RC2
Revit 2010 to 3ds Max Design 2010 vray 1.5 SP4 |
Fri, Sep 10, 2010 at 1:59:46 PM
Revit model into Max and rendered with Vray!?? |
Thu, Aug 15, 2013 at 4:51:40 PM
Vray vs. 3D Max |
Tue, Apr 26, 2016 at 7:51:22 AM
Revit to 3Dsmax vray glass problem |
Tue, Jan 21, 2014 at 8:47:01 AM
RPC and Camera's ??? --->>>Export to 3ds MAx |
Tue, Oct 9, 2007 at 3:34:27 PM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
