36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit to DWF
Tue, Jun 19, 2007 at 2:17:55 PM | Revit to DWF
ivanvasc
I've had troubles when plotting projects converted(printed) from Revit 8.1 to DWF format. Random vertical lines appears over the original drawings, crossing the sheets from top to bottom. And it does not happen every times.The DWF file displays clean, without the lines.  Is this a driver problem? Anyone could help me?
Thanks. Ivan
Wed, Jun 20, 2007 at 3:19:50 AM | Revit to DWF
Erik
I think this is a printer problem.  I have the same with my HP Plotter.  It has just gone in for repairs.  They said it was an 'interface ' problem.  They will replace the 'interface'  I will know it this fixes the problem.  The same file prints fine on our A3 printers.
However as usual HP has a spare part problem.  As soon as the products is old enough to need spare part, they do not stock them anymore so you have to buy new.  We have a grave yeard of computer parts and including a full HP plotter with one fauly part :-)
Wed, Jun 20, 2007 at 8:29:00 AM | Revit to DWF
ivanvasc
I think you're right; the plotter I'm using is an HP and with the EPSON printer I have no troublles. I'm transmit your information to the bureau service. Thanks
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:41 PM
DWF Linking
Thu, Aug 23, 2007 at 12:55:32 PM
Can anyone help me understand DWF's in Revit...Please?
Wed, Jun 21, 2006 at 1:22:46 PM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:11 AM
help! dwf for 2d plans
Sun, Feb 26, 2006 at 8:15:57 PM
Page generation time: 1.3563
