78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Sheet´s Tags
Tue, Jun 19, 2007 at 1:37:49 PM | Sheet´s Tags
concuchi
I usually work in 24x36 in sheets. Sometimes the drawing file does not fit in the sheet and i have to rotate the drawing and the title´s tag also rotates. How can i rotate the drawing without rotating the title sheet tag?
Tue, Jun 19, 2007 at 2:17:32 PM | Sheet´s Tags
broncos4life
4 Stars: 10 Votes
The way I usually do this is by adding a section box to the view if there isnt one, and then rotating the section box.  This will rotate the drawing with out reflecting to the model itself, and also shouldnt rotate the title.
Tue, Jun 19, 2007 at 5:42:19 PM | Sheet´s Tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Turn on and Rotate the crop region in the reverse direction to what you want the view to rotate.  No need for a section box.
Regards,
Chris.
Tue, Jun 19, 2007 at 5:44:56 PM | Sheet´s Tags
broncos4life
4 Stars: 10 Votes
Opps, my mistake, i said section box, but in reality I was thinking crop region.  Thanks for the heads up.
Wed, Jun 20, 2007 at 7:58:58 AM | Sheet´s Tags
concuchi
THANKS  BOTH OF YOU!!!!!!!!!!! YOU REALLY ANSWER VERY QUICKLY!!!!
tags tags tags
Tue, Mar 20, 2012 at 12:10:23 PM
Tags linked in more than one view
Fri, Feb 27, 2009 at 6:21:47 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
MISSING elevation tags
Mon, Sep 17, 2018 at 10:55:17 AM
room tags
Thu, Aug 13, 2009 at 3:54:34 PM
Page generation time: 0.3043
