38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Level in Exterior Elevations
56 Posts No Rating |
When placing exterior elevation views on a sheet, I have run into a problem. The levels appear opposite each other. For instance on a north view they are one one side, while on a south view they are on the opposite side. I would prefer to have them on the same side so the views look better on the sheet. Anyone know how to do this? Thanks
Click on the box at the end of the level line and toggle them on/off.
That's odd and shouldn't be happening unless someone had set the level datums to 2d extents and dragged them over each other to flip the direction? Level datums should always be on the same side?
Regards,
Chris.
Level Marks??? |
Wed, Apr 8, 2015 at 2:06:31 PM
Shadows on Glass in Exterior Elevations |
Thu, Mar 27, 2014 at 7:44:04 PM
exterior elevations and line weights |
Fri, Jul 20, 2007 at 12:06:07 PM
Hiding Level Bubbles to internal elevations |
Tue, Dec 10, 2013 at 4:10:45 PM
Level elevations |
Thu, Sep 11, 2014 at 12:54:39 PM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
