Forums >> Revit Building >> Technical Support >> Sloped Railing
7 Posts No Rating |
I am designing an aluminum football stadium seating. How do I create a sloped guardrail to prevent people from falling off the side and to also be used to this to divide the booster club sections from standard seating? (See Image attached) I know how sloped rails are auto created with ramps or stairs, but in my case the rail is independent of those. I attempted to host the rail to the side of the beam then I created a sloped reference plane and tried to host it to that also. Please help. Thanks.
Edited on: Mon, Jun 18, 2007 at 1:53:35 PM
From what i have seen Railings can only be hosted to stairs and ramps. To make one that is sloped and not hosted you would have to create a railing in place by hand which is very time consuming. I would suggest if you have a football staduim you should put actual stairs in where you have an isal (sp**). Thoes really are the only 2 ways i can think of. Grant Doherty
You have a couple of choices that will work. If I undersand your project, you have stepped seating area with railing on a slope to match. You could do the area where the railing is as a stair with big treads. But railings can also be hosted by floors so I would probably go that route if your floor is the traditional concrete with a sloping bottom and stepped top. To do this, just model that portion of the structure that is uniform thickness as a sloping floor and host your railing on that. The steps could be seperate flat floors joined to the sloping portion.
IT IS FAIRLY SIMPLE TO DO A SLOPED RAILING ON A CUSTOM MADE STAIR OR STEPS. PLEASE SEE ATTACHED JPG.
there is al so the option of making it as an inplace family
Sloped railing along a wall |
Sat, Oct 27, 2012 at 6:59:22 AM
Sloped railing on sloped floor/ramp |
Tue, Dec 9, 2008 at 9:25:01 PM
Railing on curved/sloped wall |
Wed, Nov 21, 2018 at 12:06:54 AM
13
Curved railing. |
Fri, Nov 15, 2019 at 11:36:40 AM
Add railing to existing stair |
Tue, Oct 29, 2013 at 7:49:40 PM
Members: | 2100683 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
