117 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Create in place sweep
Mon, Jun 18, 2007 at 9:11:03 AM | Create in place sweep
utearch1
I have a wall with an angled top. Can someone remind me how to create a wall sweep that follows that outline.
 Thanks
Mon, Jun 18, 2007 at 10:47:20 AM | Create in place sweep
broncos4life
3.5 Stars: 11 Votes
You can either go into 3D and do a create a componant in place and use sweep and the pick a path...or you can go to the elevation of that wall, and set the wall as your plane and sketch a 2d path in elevation.  Then you can eitehr draw your sweep profile, or load one.
Hope that helpsGrant Doherty
Mon, Jun 18, 2007 at 11:17:21 AM | Create in place sweep
utearch1
Thanks, but how do I go about sketching a 2d path? Do I go into solid component/sweep? Or is there a different way?
Mon, Jun 18, 2007 at 11:34:27 AM | Create in place sweep
broncos4life
3.5 Stars: 11 Votes
Thats what I was thinking yes, Create Componente in place -> Solid -> Sweep -> Sketch 2D Path
Mon, Jun 18, 2007 at 11:36:49 AM | Create in place sweep
utearch1
Thanks, I got it to work.
Tue, Sep 15, 2009 at 4:43:47 PM | broncos4life
arkitektonik
This was helpful. Though I noticed that when I did my sweep this way to follow a certain profile and path, the element properties that are usually associated with a "wall sweep" were not part of this specific sweep (such as add/remove walls, modify returns, etc). This sweep acted like a typical solid model, and are not in the wall sweep family.
Is this right or did I miss a step or something? Or is there a way I could make it act as a wall sweep that respects openings, windows, adding walls, returns, etc?
Thanks
Quoting broncos4life from 2007-06-18 11:34:26
"Thats what I was thinking yes, Create Componente in place -> Solid -> Sweep -> Sketch 2D Path"
Tue, Sep 15, 2009 at 5:22:22 PM | Create in place sweep
tim123
4 Stars: 19 Votes
Rather than doing the sweep as an in-place family, I would use the hosted wall sweep or include it in the wall family, depending on what you're trying to achieve.  Both of these methods can be controlled to respect openings or windows etc.
If you're using 2010, click the down arrow under walls for hosted sweeps, or edit the wall and add sweeps to the wall family (in edit mode, under sweeps).
Wed, Sep 16, 2009 at 11:31:28 AM | tim123
arkitektonik
If I'm right the problem with this method is that it only puts the wall sweep in a horizontal or vertical position, so we go back to the initial problem of how to create wall sweeps that follows a weird-shaped outline that respects openings.
Quoting tim123 from 2009-09-15 17:22:21
Wed, Sep 16, 2009 at 4:58:12 PM | Create in place sweep
Bronsart
I do sloped wall caps all the time.  I do in-place family sweeps because of the sloped walls.  It gets really fun when you're trying to put a cap on a sloped curved wall.  I those cases, there are two options...
1. If the cap is rectangular, then use a floor or roof.  You can adjust the points on the floor/roof (sim. to a topo), and still attach the top of wall to the floor/roof.
2. If the cap is non-rectranglar, you still have to do step one because you can't edit profile a curved wall.  After you attach the wall to the floor/roof, hide the floor/roof in all your views.  Then I do an in-place family to do the cap (sweep - blend).  Your path will be the curve of the wall (in plan view) and the blend will be the same profile, but at two different elevations.
Hope that helps.
Wed, Sep 16, 2009 at 8:12:36 PM | Create in place sweep
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I love in place models when it comes to slopes and angles. However, I have run into one major issue with that and now try to avoid them. When trying to edit a in place sweep with 2D lines if you start it with 3D edges is impossible. So if you created multiple sweeps together with 3D edges and needed to adjust them, then you can only adjust them with 3D edges.
If anyone knows a way to resolve this problem, please let me know.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Thu, Sep 17, 2009 at 9:10:42 AM | Create in place sweep
#11
Bronsart
I am not sure if this answers your question...
When I draw the sweep, I do not use "Pick Path".  I tried this after I posted earlier and my wall caps were not staying verticle to the wall.  The angles were way off.  I use the sweep blend and draw my path in plan view.  I have a "hardscape" level that I base all my site walls, pool, etc.  The blend part of the sweep is the change in elevation of the profile.
Hope this helps...
CREATE IN PLACE SWEEP GONE WRONG
Mon, Jan 28, 2008 at 1:11:49 PM
In place sweep- change of level?
Tue, Apr 8, 2014 at 7:33:58 AM
Profile uploading for model in-place component sweep
Sun, Oct 21, 2012 at 6:28:15 AM
Can't Create Sweep
Wed, Sep 20, 2006 at 2:39:48 PM
Having problems when trying to create a Steeple using Sweep
Wed, Apr 28, 2010 at 2:29:20 PM
11
Page generation time: 0.8799
