90 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
![5 Stars: 3 Votes](/images/stars_5.gif) |
OK DOES ANYONE OUT THERE KNOW IF I CAN GET RID OF THE ELEVATION INSTANCE PARAMETER OF A WALL CABINET FAMILY? IS THIS A SYSTEM THING THAT CANNOT GO AWAY? BASICALLY I WANT MY TOP OF CABINET PARAMETER TO DETERMINE THE TOP OF WALL CABINETS SO WHEN I CHANGE BETWEEN DIFFERENT HEIGHTS OF THE SAME KIND OF FAMILY IT GROWS/SHRINKS FROM THE BOTTOM AND NOT THE TOP. I AM INCLUDING ONE OF THE WALL CABINET FAMILIES WE BORROWED FORM THE WOODSMITHS INSTITUE WEBSITE THAT WE TWEAKED TO BE OUR OFFICES STANDARD. FEEL FREE TO THROW IT INTO A GENERIC PROJECT AND SEE WHAT I AM TALKING ABOUT. THANKS IN ADVANCE
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
The 'Elevation' parameter is added to your casework family when the family is loaded into the project. You could try starting your casework families as a 'generic model' then switching them to be in a casework category as I recall theis removes that elevation parameter problem.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Negative, I tried this and the elevation parameter was still present. Could this be a bug? I tried making a family independent of his and it was behaving the same way. I've never had this problem before!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
![ementaldesign Avatar](user_avatar/27598.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
Try this one.
Oh and sorry, I didn't recreate the whole family so there are some things to tweek (i.e. Symbolic Lines...) I just tried to fix the height issue.
Casework Graphics |
Thu, Aug 18, 2011 at 3:53:04 PM
Void cut in nested casework family |
Tue, Oct 15, 2013 at 12:46:49 PM
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:40 PM
Phantom Casework |
Tue, Aug 28, 2012 at 12:25:48 PM
Casework below countertop not visible. |
Wed, Jan 27, 2010 at 2:16:58 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
