134 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> parameters in Wall Family
Fri, Jun 15, 2007 at 9:34:17 AM | parameters in Wall Family
chudy
1 Stars: 1 Votes
hi all
i was wondering if there is a way to add any parameters into wall families like in other families created in Family Editor?
Fri, Jun 15, 2007 at 9:36:09 AM | parameters in Wall Family
broncos4life
3.5 Stars: 11 Votes
Im not quite sure of what you mean...could you reiterate?  What are you looking to do with the walls?  From what Im used to walls dont really have a family editor, but you can do alot with them still inside of the project, so what are you looking at chaning about a wall?
Grant Doherty
Fri, Jun 15, 2007 at 9:43:37 AM | parameters in Wall Family
chudy
1 Stars: 1 Votes
i want to have information about cost in the family. normaly in other elements i can put a new parameter in Family Editor.........but i can't edit Walls in Family Editor Puh
Fri, Jun 15, 2007 at 9:47:25 AM | parameters in Wall Family
chudy
1 Stars: 1 Votes
Sat, Jun 16, 2007 at 8:33:25 AM | parameters in Wall Family
Aguel
Aguel Avatar
4 Stars: 8 Votes
Walls are system family therefore you can't edit its parameter in the family editor however you can make a new type out of it. If you are looking to put a cost parameter then you can do that in the schedule.
Mon, Jun 18, 2007 at 6:33:49 AM | parameters in Wall Family
chudy
1 Stars: 1 Votes
hello, thanks for your reply Smile
i was just hoping that i'm wrong Puh cause its weard a little bit for me that i can't put cost parameters into a wall family.....
with schedules, there is a little problem, see PIC1.
its a schedule with costs included, it looks ok, but when I change one of the wall types, costs stay the same...... Puh see PIC2
now see PIC3. you can see that all my cost parameters that i put in the schedule are now in my wall familly, i hoped that
when i put the costs in here thay will show in all walls of this type.....i was wrong Puh when you type them here they will only
show in that one element.
maybe someone knows if Autodesk will make it possible to put parameters directlly to a system family? :D
Dawid Ochryniak
Mon, Jun 18, 2007 at 6:47:20 AM | parameters in Wall Family
chudy
1 Stars: 1 Votes
Dawid Ochryniak
Mon, Jun 18, 2007 at 6:58:51 AM | parameters in Wall Family
Aguel
Aguel Avatar
4 Stars: 8 Votes
In your schedule I don't know which one is the cost? The cost  should be a calculated value parameter and it's a function of your wall area or volume to be able to get different amount for each wall instance.
Hope this helps
Mon, Jun 18, 2007 at 7:28:36 AM | parameters in Wall Family
chudy
1 Stars: 1 Votes
cost is the last column is the sumary cost of all included costs. it is calculated automaitcally. but this is not the problem. see the diffrence between PIC1 and PIC2. I changed one of the wall types but the summary cost is still the same.
Wall hosted family can't be hosted on curtain wall?!
Fri, Oct 22, 2010 at 7:13:05 AM
Cant edit family parameters?
Wed, Jul 15, 2009 at 1:36:27 AM
Glulam Family Parameters
Tue, Sep 24, 2013 at 9:16:35 AM
Door family - how to delete unwanted parameters
Tue, Feb 7, 2006 at 3:25:02 AM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:38 PM
Page generation time: 4.0518
