38 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> Site TOPOs
25 Posts No Rating |
I am try to create a site topo in revit using the use imported, import instance, my cad file does have all the levels in 3d ie having a z co-ordinate but it will not create the topo. The cad file i am using is an OS data map with the level heights included, revit does not seem to work with these point heights. Can anyone help? Thanks
2 Posts No Rating |
I just created a Topo based on a CAD file, I found that I had to make a seperate CAD file that only had the points and contours,nothing else. I then imported that into Revit and was able to create the topo fairly accurately from the use imported feature. The CAD file I had did have Z axis information on all points though. I hope that helps.
Kelly Imparato Proteus Group, LLC |
importing topos for a Site Plan |
Sat, May 28, 2005 at 10:20:13 PM
linking topos |
Wed, Aug 8, 2007 at 6:40:27 PM
Abolute Elevation and Topo Points - Revit Architecture 2009 |
Tue, Feb 9, 2010 at 6:02:25 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ] |
Tue, Feb 25, 2014 at 4:19:15 PM
26
Creating a Site |
Sat, Apr 10, 2010 at 6:19:21 PM
14
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
