111 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> integer parameter problem
18 Posts No Rating |
Hi, here comes my second post. I try to set a integer parameter for my window muntins or mullion.. doing array, add label, and test the flex, all fine. Then I align the edges of each muntin to ref plan of the edge of window and lock them. Then when I try to flex the window width, I got a error message (see attached image). I'm sure it shouldnt be like this, which step I got wrong or missing? please help, thanks in advance!
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Expand the error, look at the ID# of the item giving you the problem, write it/them down or copy it. Click cancel. Go to Tools > Elements Ids > Select Element by ID. Enter the id number. It will hilight your problematic element. Usually when I get this error I end up needing to re create the element that is causing the problems. Another helpful thing when dealing with constraint errors is to turn on Automagic Sketch Dimnsions. This can be done in the View Graphics dialogue (Type 'VG') under the Annotation Categories tab. Expand Dimension and check Automatic Sketch Dimensions. Check to see what constraints Revit is putting on the element causing the problem and you can unlock or change the dimensions as needed. HTH!
'Inconsistent units" error in parameter formula; length vs integer |
Fri, Dec 13, 2013 at 10:37:04 PM
Checking if a parameter value is a integer or a real |
Wed, Jan 16, 2008 at 6:48:49 AM
Conditional toggle yes no formula |
Thu, Mar 3, 2016 at 8:49:22 AM
How/When do I use each Parameter? |
Wed, Jan 21, 2009 at 10:21:02 AM
family with (3) or more yes/no options |
Wed, May 18, 2016 at 7:38:51 AM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
