51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> wierd error
43 Posts No Rating |
Last week, my workmate was working on a file when he tried to saved to central and he got this message: "this local project file has been saved by user "xxx", current user is "aaa". Please change your user name or stop working on this file. Finally we had to save it under a different name and copy from that file to the original. The problems is that this is not the first time this occurs, and the user "xxx" hasn't work on "aaa" computer station. do you know why this happened?
Somebody opened your central file .... picked/did something .... then closed it. I highly recommend that you set up rules for your office that does not allow this. If you want to just look at / copy from (... whatever) a project central file, then you MUST OPEN WITH DETACH FROM CENTRAL option checked!
I see... I will check that out.
Matias Santini |
Revit 2009-Wierd stuff happening. |
Thu, Jun 25, 2009 at 2:46:00 PM
Wierd Crash |
Tue, Nov 8, 2005 at 3:43:05 PM
Display shifting in Context tab |
Thu, Nov 12, 2009 at 4:19:17 AM
lost .rft files |
Mon, Jun 28, 2010 at 6:50:29 PM
A Serious Error [ 1 2 ] |
Thu, Jul 26, 2007 at 11:41:07 AM
21
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
