71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> SHADOWS ON SITE PLAN ORIENTED TO PROJECT NORTH AND NOT TRUE NORTH
Sat, Jun 9, 2007 at 7:30:37 PM | SHADOWS ON SITE PLAN ORIENTED TO PROJECT NORTH AND NOT TRUE NORTH
DesertArc
I'm doing a solar / shading study for a client using Revit Architecture 2008.  When I turn on the shadows for the site plan, all of the shadows are oriented for PLAN NORTH and NOT TRUE NORTH.  I have to add 120 degrees (the rotational angle between PN and TN) to the azimuth to orient the shadows correctly.  I've tried selecting the "Relative to View" box, but the results are not only wrong, but the shadows are somewhat bizarre (i.e. shadows of column capitals casting from the base and in the opposite direction of what they were before selecting it).  Why are the shadows not casting correctly and how do you fix it?
Thanks!
Sun, Mar 9, 2008 at 11:08:24 PM | SHADOWS ON SITE PLAN ORIENTED TO PROJECT NORTH AND NOT TRUE NORTH
CAArchitects
We have also had this problem, and I've found that if we start a new project with our template the shadows orient to project north, but if we start from scratch without a template the shadows are correct for true north!
Is this a bug, or do we need a new template? Is there a way to recover our current projects which have this problem?
 Stuart
CA Architects
true north and plan north effect on sun angles
Mon, Feb 13, 2006 at 10:13:17 PM
Project North and True North
Fri, Feb 3, 2006 at 6:20:18 PM
true north & callouts
Thu, Oct 2, 2008 at 11:16:39 AM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
Shadows set using Geographic location relate to Project North not True North
Sat, Mar 4, 2006 at 2:15:27 AM
Page generation time: 1.6409
