74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> working with Pads and toposurfaces
Fri, Jun 8, 2007 at 2:24:15 PM | working with Pads and toposurfaces
bigstein
Hi All
I'm having some confusion with trying to modify the building pad and toposurface for an elevator pit.  I first created a building pad for my project, then tried to edit the pad to 'cut out' for the elevator pit, but something isn't working or I am missing a step in the settings.
Any help or advice would be welcomed
Thanks
BS
Fri, Jun 8, 2007 at 3:17:50 PM | working with Pads and toposurfaces
Atomsk
5 Stars: 3 Votes
When i make an elevator shaft or a stair well i use an "opening"
Go to the design bar and choose Modeling --> Opening ---> Shaft Opening
This should cut through anything: slabs, roofs, and topos.  You can adjust the top and base to go as far as you want and not have to worry about modifying everything that you want it to cut through.
LMK if this helps.
Revit 2010
Pads and phases
Wed, Mar 28, 2018 at 6:44:34 AM
Pads and Phases
Wed, Oct 28, 2009 at 4:09:22 AM
Can you tell a building pad to cut multiple toposurfaces? Revit 2014
Tue, Aug 12, 2014 at 2:45:17 AM
Topography and pads trick
Mon, Jan 14, 2013 at 2:53:19 PM
Building Pads...how to see existing pads when outlining a new one?
Sun, Apr 10, 2011 at 12:39:56 PM
Page generation time: 2.4306
