55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Schedules combining 2 text fields in to 1
Wed, Jun 6, 2007 at 9:03:21 PM | Schedules combining 2 text fields in to 1
BSMITH82
Basically i want to know if i can combine 2 test fields into one so i can have the information that i have put on the 2 fields in the one column i.e
frist field is Type Comments
second field is Comments
and if i can comnine touse fields together so the can be called Overall Comments
is there a formular to do this i know i can do it with numbers
Thu, Jun 7, 2007 at 9:13:27 AM | Schedules combining 2 text fields in to 1
ebtaylor
3 Stars: 2 Votes
do you mean just grouping the 2 text fields and have a heading above them?
similar to the attached?
Thu, Jun 7, 2007 at 10:43:58 AM | Schedules combining 2 text fields in to 1
TomDorner
4.5 Stars: 25 Votes
Revit does not support text concatenation via formula.  The best you can do is the group heading thing as suggested.
Tom
Thu, Jun 7, 2007 at 6:16:14 PM | Schedules combining 2 text fields in to 1
BSMITH82
YES ebtaylor HATS WHAT I MEAN IS THERE A LINK TO ANOTHER FORUM TO SHOW ME HOW TO DO THIS
Fri, Jun 8, 2007 at 7:55:11 AM | Schedules combining 2 text fields in to 1
3.5 Stars: 400 Votes
The fact that we can't combine strings is a problem and I hope they add that feature to REVIT.
What I did when I had a similar problem:
- I placed my columns side by side
- kept one of the column headings (comments) - blanked the other column (type comments)
- turned off the grid so that I didn't have the vertical lines
- added the correct grid lines to my sheet
RESULT - the field has the correct data although there is some extra spaces occasionally between the two comments.
Fri, Jun 8, 2007 at 9:10:37 AM | Schedules combining 2 text fields in to 1
ebtaylor
3 Stars: 2 Votes
take a look at this, its from Revit help from Revit 2008, look up schedules - modifing
24214_Sched-grouping.TIF
Fri, Aug 10, 2007 at 12:27:28 PM | Schedules combining 2 text fields in to 1
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
that god for this thread i am workin in mep 08 trying to create ventilation schedules and this a major problem i have been having.
http://familyjewels.typepad.com/
Graphical Column Schedule Fields
Thu, Nov 5, 2009 at 10:30:02 AM
Schedules
Tue, Oct 22, 2019 at 7:26:50 AM
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
Editing Text In Schedules
Fri, Feb 17, 2012 at 2:47:33 PM
Cursor not visible in schedules, Revit Structure 2014
Tue, Apr 29, 2014 at 2:16:15 PM
Page generation time: 0.4533
