127 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Sloping Structural Members
Sun, Jan 9, 2005 at 2:14:46 AM | Sloping Structural Members
form
How do you slope structural members such as steel girders. I'm doing a framing plan for a steel building using the families that came with Revit but they seem to be tied to the plane they were created in. Help! thanks, Formarch
Sun, Jan 9, 2005 at 4:09:42 PM | RE: Sloping Structural Members
benbolivar
Hi, This issue interests me because I am about to do sloped girders for a truss as well. But I would simply slope the plane if this is the case. I'll try it later. Thanks, Ben Bolivar
Sun, Jan 9, 2005 at 4:11:09 PM | RE: Sloping Structural Members
benbolivar
BTW, I remember that you can set the elevation of both end points so this should do the trick as well.
Sun, Jan 9, 2005 at 5:32:40 PM | RE: Sloping Structural Members
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Simply draw a reference plane at the angle you wish to have the girders or joists at and set this as the work plane before drawing in the members.
Curved structural members??
Tue, Apr 6, 2010 at 11:35:56 AM
Structural Members not showing up in any view- Revit Arch 2011
Thu, May 19, 2011 at 12:11:08 PM
Structural Members in Revit
Tue, Jan 20, 2009 at 6:58:51 PM
structural members along dxf lines
Mon, Oct 24, 2005 at 3:40:36 AM
Cutting Structural Framing Members with other members in Revit 2012
Tue, Jan 31, 2012 at 10:54:50 PM
Page generation time: 4.8646
