85 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Disappearing Titles
Wed, Jun 6, 2007 at 5:38:28 PM | Disappearing Titles
Keiffer
Help, somehow I have lost the titles off all my sheets in the entire project.
Wed, Jun 6, 2007 at 5:41:17 PM | Disappearing Titles
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Select your view on the sheet and in the properties drop down in the top left corner it probably says something like "No Title", just change this to the appropriate view title your require.
If this doesn't work it sounds like someone has managed to delete the actual view title family from the project.  Reload it and all should be well.
HTH.
Regards,
Chris.
Wed, Jun 6, 2007 at 6:14:26 PM | Disappearing Titles
Keiffer
That worked!!!!! Thank you very much.
Purge unused Viewport Titles
Thu, Aug 30, 2018 at 10:41:50 AM
11
Turn off view titles
Tue, Jan 9, 2007 at 4:29:13 PM
Disappearing Callouts
Thu, Feb 14, 2008 at 11:36:28 AM
window frames disappearing
Thu, Aug 18, 2005 at 3:05:09 PM
Viewport titles moving
Mon, Nov 10, 2008 at 10:16:49 AM
Page generation time: 0.1861
