83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rendered Walkthrough
Wed, Jun 6, 2007 at 10:05:53 AM | Rendered Walkthrough
jsneed665
I tried to render a walkthrough with 500 frames at 5 fps 150dpi.  I was able to export it as a hidden line and shaded view but when I try to playback the rendered walkthrough I have the first frame and the rest are just fuzz like tv static.  What could be wrong?
Jen
Wed, Jun 6, 2007 at 10:48:55 AM | Rendered Walkthrough
jsneed665
I am using Revit Architecture 2008
Wed, Jun 6, 2007 at 5:31:16 PM | Rendered Walkthrough
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What codec did you export to?  As it sounds like the codec you used is bodgy.  I generally always export walkthroughs as either jpg frames or uncompressed avi.
Then I do the compression afterwards using Camtasia or Move Maker.
Regards,
Chris.
Thu, Jun 7, 2007 at 7:39:52 AM | Rendered Walkthrough
jsneed665
Im not sure what codec I used, I think I left it uncompressed frames.
 I did figure it out though.  I was cancleling the export before it was done to make sure that it was working before I let it run all night.  I let it run anyway and this morning it looks good.
Thanks
Rendered walkthrough is blurry
Tue, Dec 2, 2014 at 1:41:45 PM
best way to do a rendered Walkthrough video?(Student)
Mon, Sep 19, 2016 at 6:31:25 AM
Walkthrough in realistic view, not rendered
Wed, Aug 27, 2014 at 12:00:39 PM
rendered walkthrough?
Mon, Jan 2, 2012 at 1:43:20 AM
How Do I set the DPI for a Rendered Walkthrough ?
Mon, May 28, 2007 at 11:54:38 PM
Page generation time: 0.4280
