Forums >> Revit Building >> Technical Support >> import image 2008
89 Posts No Rating |
g'day, i imported an image quite ok in one project but can not get the image into an other project. (same image ) after selecting the image it does not appear as attached to the curser as a "ghost" the help file does not tell anything about visibility settings and the like. thanks, robert
Just check that "Raster Images" are turned on in your visibility settings first.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
thanks chris, it works like a charm. your blood is worth bottling mate. regards, bob.
16 Posts No Rating |
Chris- I have 2009 and have a similar problem, however, we seem to have reached an image import limit. We have been bringing in our code data as a .jpg because the Revit text formatting is so limited. (tabs, bullets, etc.). Regardless of the text issue... images seem to be disappearing. At one point they will insert properly and then the next time the file is opened, they will be blank or black. One image is already in the file and Images are on. However, now, every new image that I bring in is blank (ghosted). Any thoughts?
how to import revit 2008 data to autocad 2008???? |
Tue, Apr 8, 2008 at 10:12:03 PM
Image Import Problems |
Tue, Jun 5, 2007 at 12:21:01 PM
Image Import Issues |
Wed, Jun 24, 2009 at 7:47:33 AM
IMPORT BACKGROUND IMAGE TO RENDER IN RAC2009? |
Tue, May 6, 2008 at 12:25:34 AM
Swap Image | Change Image Link / Reference |
Tue, May 1, 2012 at 1:42:27 PM
Members: | 2103940 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
