46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stair to Slab Connection
Tue, Jun 5, 2007 at 11:24:39 AM | Stair to Slab Connection
Spartacus
I'm using Revit Building 2008 and have a steel pan stair with concrete topping that is connecting to my slab that also has a concrete topping and in plan it is showing the line that connects the stair and slab and I don't want to see that in plan.  The only thing I can think of to fix this would be to put a mask over it in plan but I wanted to see if there was a better way.
I've attached an image that shows what I'm talking about.
Thanks for the help
Tue, Jun 5, 2007 at 2:38:20 PM | Stair to Slab Connection
sdbrown
5 Stars: 3 Votes
YOu can just hit it with the linework tool/set to invisible.
Tue, Jun 5, 2007 at 3:27:53 PM | Stair to Slab Connection
Spartacus
The only thing about setting the linework to invisable is that it also has to hide the slab edge which I do want to be shown next to it where there is an opening, I could draw a detail line in where I want to see it, but I just assumed that revit had a better fix for this.
Tue, Jun 5, 2007 at 3:46:26 PM | Stair to Slab Connection
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
After setting the slab edge to invisible you should see two blue control points at the end points of the line. You can move these control points to the edges of the stair and it will hide only the line between the points.
Tue, Jun 5, 2007 at 3:49:07 PM | Stair to Slab Connection
coreed
coreed Avatar
4 Stars: 16 Votes
did you try Join Geometry?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 5, 2007 at 3:52:47 PM | Stair to Slab Connection
Spartacus
Thanks I used the blue grips and that worked great.  And it will not let you join anything with a stair...
Precast stair with notch connection
Fri, Aug 26, 2016 at 1:05:16 AM
Stair Showing Below Mezz Slab
Fri, Jan 27, 2012 at 8:21:11 AM
how to connect monolithic stair to f.c. slab
Fri, Apr 17, 2009 at 2:38:26 PM
Cleaning up a Stair Tread & Floor Connection
Thu, Nov 3, 2016 at 8:45:40 AM
Creating concrete stairs from raised exterior slab
Sat, Oct 25, 2014 at 10:26:44 PM
Page generation time: 0.7032
