131 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> new to revit
Sun, Jun 3, 2007 at 8:35:14 AM | new to revit
judeazion8
I am in the process of drawing a site plan
when I open it up to pick points it doesn't show the lines you normally see and it only shows up in the floor plan and the 3-d . It doesn't show up while I am on the site plan view.
what am i doing wrong?
Sun, Jun 3, 2007 at 4:29:49 PM | new to revit
Tmifsud
Two things to check are view range and visibility/graphics.  The default setting for "primary range - top"  and "primary range - cut plane" are at 200' above the associated level, while the bottom of the range and the view depth are set to 0' from level below.   Under visibility graphics overrides - model categories make sure that topography is show.  HTH
 Troy
www.myCADD.com
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:39 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:40 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:03 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:25 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:53 PM
16
Page generation time: 3.4802
