77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Walkthrough down stairs
Thu, Jan 6, 2005 at 2:18:16 PM | Walkthrough down stairs
Studedude
I'm having no luck "walking" down stairs in a walkthrough. Has anyone found a solution to this? Thanks. Jim
Thu, Jan 6, 2005 at 8:12:06 PM | RE: Walkthrough down stairs
ale02
ale02 Avatar
3 Stars: 3 Votes
Previously, I have been struggled with this issue too. Try to assign your key frame elevation during your lineup of your walkthrough path and not after it. You should be able to travel between 2 levels by then. Guess you have no luck changing the path elevation from sectional view or property dialogue box, right? Hope this help! Smile
Life is never easy but nor it should be complex. Just stay simple Smile
Sat, Jan 8, 2005 at 5:57:55 AM | RE: Walkthrough down stairs
JTF_8
There is a thead about this at AUGI. I had been trying to figure this out for some time and then I stumbled upon that thead and it straightened me out in no time. You should see the amazing walkthrough I did going up some stairs resently (Just amazing). The trick is to view your walkthru in 3D mode where you can adjust the camera up & down and also adjust the angle of the camera up & down.
Sun, Jan 9, 2005 at 8:09:04 PM | RE: Walkthrough down stairs
ale02
ale02 Avatar
3 Stars: 3 Votes
JTF_8, What is the thread's name/ location in AUGI? So I can have a look on it as well as your walkthrough. Thanks!
Mon, Jan 10, 2005 at 5:02:57 AM | RE: Walkthrough down stairs
JTF_8
Thread is listed under Tips & Tricks Posted by Kirky. Thread name is Simple Walthrough
Mon, Jan 10, 2005 at 11:41:19 AM | RE: Walkthrough down stairs
Studedude
Ah, terrific. I was certain I was not the only one struggling with this. Thanks very much for the reply's. I'll go check AUGI and see if I can get the results I need. Will keep this forum posted with my success. Jim
Walkthrough - Stairs not visible
Wed, Feb 21, 2007 at 9:39:11 AM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
walkthrough questions
Sun, May 10, 2009 at 7:49:41 PM
New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 6:01:12 PM
walkthrough
Wed, Aug 1, 2012 at 5:43:43 PM
Page generation time: 0.3051
