45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Split Faced CMU model material pattern help???!?!?!?
Thu, May 31, 2007 at 3:42:22 PM | Split Faced CMU model material pattern help???!?!?!?
jmqrsq
5 Stars: 3 Votes
Ok let me start off saying I know very little on how to create custom hatches/patterns/.pat files. Now I see in ADT 2007 there is a CMU_split_faced.pat hatch pattern that I want to use in my Revit model. I try to create a new custom material pattern in Revit, use the .pat from the ADT split faced .pat file and it says there is no model info in it. How can I make this a model material surface pattern does anyone know how to manipulate the text file (.pat) so that I can use it? we basically have running bond exteriors with banding of split face and non. Anyhelp ASAP would be greatly appreciated.
Thu, May 31, 2007 at 3:49:12 PM | Split Faced CMU model material pattern help???!?!?!?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
taken from my blog:
8. How do I change a model pattern to a drafting pattern or vice versa?Edit the PAT file using notepad and add or change the following values:;%TYPE=MODEL for model or;%TYPE=DRAFTING for drafting.You can also set the units with the following operator:;%UNITS=MM to set to millimetres…
HTH.
Regards,
Chris.
Fri, Jun 1, 2007 at 7:30:42 AM | Split Faced CMU model material pattern help???!?!?!?
jmqrsq
5 Stars: 3 Votes
Again thanks for your help Chris. You know I realized this easy fix after I posted the question and you beat me to the anwer post. =) I am trying to take out the squiggly lines though in the ADT2007 CMU_SPLIT FACE.pat and replace it with a sand hatch. I dont suppose you have the fix for that do you?
Fri, Jun 1, 2007 at 9:00:26 AM | Split Faced CMU model material pattern help???!?!?!?
Thread Post Kudo! #4
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Here is a pattern for Split Face Cmu that I made. You are welcome to it.
Fri, Jun 1, 2007 at 12:34:29 PM | Split Faced CMU model material pattern help???!?!?!?
jmqrsq
5 Stars: 3 Votes
Hey thanks alot. super close to what I am looking for. do you happen to know how i can easily make the sand pattern a little more dense? thanks a ton again!
Fri, Jun 1, 2007 at 1:20:30 PM | Split Faced CMU model material pattern help???!?!?!?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I had to play around with the numbers contained in the pattern file to get the correct density I wanted. The smaller the numbers for dash length, space and offset will achieve a denser model pattern. HTH
Fri, Jun 1, 2007 at 2:01:40 PM | Split Faced CMU model material pattern help???!?!?!?
jmqrsq
5 Stars: 3 Votes
Great! Thanks alot for your generosity. I will tweak the numbers to get what i need. Thansk again both of you guys.-
split face CMU pattern
Wed, Jan 28, 2009 at 6:08:55 PM
CMU Wall
Thu, May 7, 2015 at 12:15:48 PM
CMU Hatching/ Alternate Bands
Fri, Aug 10, 2007 at 8:09:23 AM
CMU Block pattern problem (2010)
Wed, Sep 9, 2009 at 2:31:28 PM
What is the best way to hatch a CMU Wall?
Wed, Nov 4, 2009 at 7:00:30 PM
Page generation time: 1.7863
