43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Sports Fields not showing up
2 Posts No Rating |
I'm making a school for a project, and whenever I try to add in a basketball court, or a softball/baseball field, it will show up in the 3D view, and on the level, but when I render it, there will be nothing there. Anyone know how I can fix this?
Sounds as though the family you are using is either made completely of model or symbolic lines (which won't show up in a render) OR there is a ground plane turned on in your rendering settings that is above the level of the sports fields... Check these and report back. HTH.
Regards,
Chris.
sports hall |
Wed, Nov 8, 2006 at 8:20:10 AM
Schedules combining 2 text fields in to 1 |
Fri, Aug 10, 2007 at 12:27:28 PM
Multiple dimension fields in schedule |
Wed, Aug 24, 2011 at 4:31:08 PM
Adding Window Parameters/Fields for Window Schedule |
Fri, Aug 15, 2008 at 1:23:57 PM
Door Schedule Fields Clarification |
Mon, Dec 3, 2012 at 7:06:53 AM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
