Forums >> Revit Building >> Technical Support >> Elevation Tags
69 Posts No Rating |
Can you change elevation tags in 7.0? I don't want to see the view name and I need to change the text. I was able to do it in 6.1 But I got an elevation tag error when I upgraded our template to 7.0.
Thanks,
Jennifer
25 Posts No Rating |
YES - just buried in a different place...
To change this go to setting ->view tags->elevation tags
Select the 1/2" circle type and uncheck the box that marks show view name.
62 Posts No Rating |
I've been using Revit since release 5 and those elevations tags are just plain ugly. No matter how much you try there is only so much that can be modified and they are still just plain YUCK. When are we going to be allowed to create our own look for these?
39 Posts No Rating |
does anyone know if elevation tags can be edited yet? i agree that the tags provided are UGLY and BIG.
In 9.0 elevation tags are still system families and can only be customized within the system family limits.
Basically you can have two shapes, square (the rage on the East Coast) and round. You can modify the size of each shape and choose whether the elevations show name or number.
HTH
Tom
thanks, at least we can change the size and font style. That's a big help.
14 Posts No Rating |
Uh, this should be a no-brainer, but I have looked and re-looked, and still don't find how to place interior elevation markers into a legend view. anyone?
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Custom Elevation Tags |
Thu, Mar 17, 2011 at 5:09:02 AM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:57 AM
Multiple Elevation Tags |
Mon, May 24, 2010 at 3:20:16 PM
Building Elevation Tags |
Thu, Feb 17, 2011 at 9:32:02 AM
Members: | 2097999 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
