73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Nested Door family
Thu, May 31, 2007 at 1:06:46 PM | Nested Door family
TonyHa
I've been creating several different door families with adjustable swings in both 2D and 3D.  And that has worked for the most part.  But now that I want to model more complex doors - i.e. doors w/ a window, I'm thinking that it may be better to do that as a nested family.  But I'm not sure where to start.  Do I create the door panel family in a Generic.rfa file?  Or a Door.rfa file?  Any advice/guidance would be much appreciated.
Thu, May 31, 2007 at 1:25:52 PM | Nested Door family
chilenito
yea !! me too!!!! I still don't get nested families concept.
Matias Santini
Thu, May 31, 2007 at 4:34:33 PM | Nested Door family
sdbrown
5 Stars: 3 Votes
You are on the right track,  Create you door panels as generic model families, then convert them to door families using (Settings>family category and parameters) then you can assign the proper subcategories.
Now open a new door family and load the panel into it, add the parameters you need, then select the panel family and edit its properties and click the little square next to each parameter to set it to match a host parameter, ie for a double door you will have parameters in you panel like Panel  Width and Panel Height, you would in the host create these same parameters but they might = Width/2 for a double door, etc.
Then create your trim in the host family.  I've attached an example.
Thu, May 31, 2007 at 4:36:52 PM | Nested Door family
sdbrown
5 Stars: 3 Votes
Sorry here is a file
Nested door family - tags wil only show in elevation view?
Mon, Aug 9, 2010 at 9:53:33 AM
Door Hardware Schedule - nested family
Wed, Jun 20, 2007 at 5:16:24 PM
Nested Door Family w/ Adjustable 3D Swing Angle
Tue, Jul 31, 2007 at 5:34:21 PM
Controlling visibility of nested families in familes with multiple types
Mon, Jan 6, 2014 at 10:37:46 PM
Nested families stored in project - Not in family
Mon, Jun 20, 2011 at 4:21:13 PM
Page generation time: 1.3694
